Old 11-30-2011, 09:04 AM   #3 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
While both are rated as LRR, they are apparently not the same.
(make + model + rubber compound, yet even then there are differences)
The wider tyres cause more aero drag.
Heavier wheels+tyres cost you when accelerating - even if you get some of that back when coasting.
The circumference is 0.6% bigger on the 17" - so it's slightly under-registering the miles driven - you might want to compensate for that, but it's not enough to cause a 4-6mpg difference.
