Right now I'm thinking that the best idea would be to put put a copper coil into a short piece of straight exhaust pipe. That way it can be easily moved in and out. In the winter I need nowhere near the cooling capacity of my radiator, so a little extra cooling load isn't going to matter at all. If I'm running too hot in the summer I can just take it out. I don't think that will be the cse because this summer I ran with an upper grill block in 100 F weather and never had a problem.
This also would mean that I wouldn't have to worry about any vlaves or controls--I like that. I'm thinking some heater hose, some copper tubing, a short piece of exhasust pipe and I'd be all set.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
