First here is a latching relay diagram that I think would work for you, the positive pulse from alram input would actually be your momentary start output from the key switch.
Second, as there are so many ways for you to wire this up check out
Relay Diagrams - Quick Reference This is a huge resource of information that should help you figure out what you want to do
