Old 11-30-2011, 10:43 PM   #7 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by CigaR007 View Post
I wish I had the skills to render 3D objects using such programs. The learning curve looks steep.
Sometimes you can find a model of your car that someone has done for free. If not you can usually buy a 3D model of your car.
Unfortunately Blender will (as far as I can tell) only show you smoke flow around an object. Not give you numbers for things like drag. Still it might give insight on some things like air dams and boat tails.
I wouldn't expect it be able to tell you how to install vortex generators as even the professional CFD programs have trouble doing that without a real wind tunnel to verify assumptions.
