Old 12-01-2011, 11:35 AM   #26 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by mechman600 View Post
Diesel_Dave, does your Dodge have a DPF or is it a pre-DPF truck? If it has one, the last thing you want to do is cool the engine-out exhaust down. DPFs need as much heat as available, at all times. I have a feeling your truck doesn't have one, and if that's the case, never mind.
My truck came with a DPF. Your right about vehicles with a DPF--you don't want to take heat out of the exhaust. In that case you'd want to put it after the DPF. There's still quite a bit of heat there, just not as much as up bu the turbo exit.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
