Originally Posted by Piwoslaw
I think something could be arranged. Where are you from? You may have seen me on the roads in central or southern Poland.
I doubt that your '95 Previa is OBDII/EOBD compatible, but if you are good with electronics then maybe you could get a MPGuino working? Keeping an eye on certain engine parameters helps with hypermiling.
I'm from Grodzisk Mazowiecki and I'm working in Warsaw so we're practically neighbours
Yes you're right Previa is not OBD II compatible, and I thought of MPGuino, but maybe I'll find another solution for MPG analyzer.
Right now I'm planning to change the radiator fan from belt driven to electric. That will be my first modification.
