Old 12-02-2011, 06:53 PM   #1 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
1984 Volvo - MPG log for my "new" Winter beater
A 1984 Volvo 244. I picked her up a couple of weeks ago for $400. I normally ride my Suzuki DRZ400S year round, but it is supposed to be a nasty winter here in the Lower Mainland (Vancouver area).
The Canadian Volvo's were a mixed bag of parts in 1984, built in Halifax, Nova Scotia. A B21A engine with a zenith CV carburetor and an AW55 3-spd non-lockup auto, both which were Canada only bits. So finding an EPA rating is impossible. EPA rates the fuel injected 4-spd auto car at 17 mpg combined. If I can beat that with the 3-speed, I will consider it a grand success.
This car is only used for short commutes and small errands, so mileage will not be great. I will fill every two weeks or so to keep the fuel above half full, because I have a feeling the in-tank fuel pump does not work, and these cars will not run on the mechanical pump only if the fuel level drops too low. I will be looking into that.
My theory about buying a cheap car is as follows: it is silly to buy a car for between $500 and $2000. If you spend $1000-1500 and it suddenly needs a $500-1000 repair, you basically have to fix it or you have blown a lot of money on a car that no longer works. If you spend $400 and it suddenly requires a $500-$1000 repair, you simply call the wrecker to pick it up, and they will usually give you $100-200 for it, depending on the car. My plan is to tinker on this car over winter so by the time springs comes, I can turn around and sell it for as much as or more than what I paid for it. My only investment will be time, but I love tinkering anyway.
Tank #1 results
Pre-tuneup. 6.5 km commutes in 0-10C weather, so it barely gets hot. One 60 km freeway run at 105 km/h. Lots of idling time while I adjusted dwell, timing and carb just before I filled up.
189.6 km / 27.840 L = 14.7L/100km, 19.2 mpg (imp), 16.0 mpg (us)
Sort of what I expected. The next tank should be better, post-tune up.
