Old 12-02-2011, 05:59 PM   #1 (permalink)
grins2go_brett
grins2go_brett's Avatar
Velcro to attach Coroplast grill block?
Living in the desert area of Phoenix, AZ, I have to remove a lot, if not all of my grill block in the summer time. I have it cut into many sections so I can remove relatively small pieces as the temps rise in the spring, and put them back on in the fall. I've used duct tape so far, but want/need something a little cleaner and easier to remove, and less noticeable. I was thinking of using some Velcro to attach it to the grill. Has anybody tried using Velcro before, and if you have, what were your results? Thanks!
