Again and again thank you !
I'll try and do some testing this weekend unless its raining ( no garage )
Of course i will have new questions that pop up since i have a voltmeter, but have never done testing with it.
i'm not even sure how to conduct testing with it actually. ( I will do a quick review online to see how it is done.
I should add that my engine to chassis ground wire has been modified. I snapped the bolt that holds the valve cover on and so i have it attached to a something ( metal ) on the block itself and leading to the chassis.
