Originally Posted by onefstek
I used a box fan in the back. As far as smoke I used incests, it works but not as good as I would like it to.
Stefan
Surprisingly accurate results !
Did you have it blow or suck the air past the car ? I may be mistaken on this, but it would be better to have the air pulled past the car, rather than blasted at it from the front ( straighter airflow )
You might also look into a smoke machine. You can pick one up for cheap from a discount Halloween store.
http://www.google.com/products/catal...MAI#ps-sellers
Hey, so i bet it smells really nice when you do your testing eh ?
EDIT : i see you have the fan mounted the correct way ( sucking the air past the model )
