I just tried out the multimeter with the settings I had above and it shows 12 .1 which I assume is volts.
Not running of course since its sprinkling out here now.
It also shows 12.1 at the fuse box ( both wires coming from fuse box )
EDIT. I was doing it wrong .12.1 amps are now showing at the starter .
Reason: idiot !
