I'm in the process of reading your posts right now, and i'll edit this if i miss something that is mentioned above, but i just wanted to mention that i did a very thorough testing of the original main relay on the car and it checks out fine. All terminals were checked for continuity. I bought a brand new main relay and it isn't getting voltage to the pump either, but i'd bet it will check out fine.
Regarding the battery voltage, it has been run down a bit with the car not starting.
