Old 12-03-2011, 10:17 PM   #21 (permalink)
user removed
When you find the cause, it might be outside the passenger compartment, but in either case, humidity inside a car is basically the same as outside. You will get it figured out and learn that that car can't beat you that easily. The most important knowledge is not knowledge at all, just boneheaded perseverance. "I will kick that problems arse". The real question is how bad will it beat me up before it surrenders!
