Originally Posted by brucepick
Examine the wires at the fuel injectors. 2 wires at each, and one of those is the same color at each injector. That is the 12V power wire. I think on my car they are yellow with a black stripe?? But you'll have to see it on yours.
The other injector wire is a different color at each injector, and that is the ground. The ground is the side of the circuit that the computer switches on/off to control injector pulses. That's why each one has it's own distinct ground wire. The 12V + wire is always powered when the engine is running.
Anyway, now you know what color is the injector +12V wire...
Well I don't believe this will work. There is a red wire in some sort of configuration at each injector, but each red wire has a different color stripe. The remaining wire at each injector is either yellow, white or blue each with a different colored stripe. This is nuts...wiring always causes me fits!
