just cut the PGM FI relays ground. Engine dies immediately. As soon as the ground is restored all turns back to normal, and a bump-start will fire you right back up. The temprary disruption to the fuel pump is not an issue. Use a push to open momentary then all you need to do is hold it while the engine dies. See my write up for a 5th gen civic your 4th gen will be quite similar.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
