Old 12-04-2011, 10:10 PM   #249 (permalink)
gtkid2002
gtkid2002's Avatar
The Bug - '69 Volkswagen Bug Base
I wonder if using one of those small diesel engines would work with the stock VW trans. Because that would be fun to run on WVO/SVO.
Right now I'm slowly moving further away from this project sadly. I might have to scrap everything and move on because of some political views I have, but that's another story, and may or may not happen for a while.
Although. Since the Baja was FI originally, I found this little box plugged into the back of the speedo. I kept it, not knowing what it was till I cracked it open. Turns out it's a switch set that converts the stock VW speedo cable to mechanically switched pulses. So I could have essentially a VSS without having to do any major homebrew stuff. Just would have to do a pinout and some math.
I suck at coding! Woo!
1969 VW Bug - Daily Driver
1975 VW Baja - Current Project
Priors:
1989 Honda Prelude Si 4WS (RIP)
1995 Honda Prelude Si (Traded)
1980 Fiat Spider 2000 (Sold)
