1991 F-250 fuel cut off 302 5-speed
Rigged up a heavy duty switch on the fuel injectors power wire. Also have a heavy duty rheostat in that circuit to vary the voltage to all the injectors.
The resistor value is about 0 to 50 ohms. Have to turn it to 0 ohms to start it cold then can turn it up towards 50 ohms after its warmed up to lean it out. I know it's brute force but i've gotten 19 MPG on the highway by doing this, and putting a check valve in the vacuum line to the fuel pressure regulator. This is OBD-I stuff. OBD-II might be too smart for this to work.
I keep engine braking to a minimum because it's still braking.
