Old 12-07-2011, 07:19 PM   #53 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
You can get predictable and repeatable results but they are unlikely to represent anything like the real world. I put up a thread on MicroCFD. Using that it gives you drag and even lift calculations. It also allows you to scale your object to the correct size. I plots pressure, vorticity, temp, and can plot stream lines.
Note its not free but it has a free 3 day trial. You can work around that if so desired.
The Following 2 Users Say Thank You to ConnClark For This Useful Post:
Cd (12-07-2011), Sven7 (12-07-2011)
