Thread: Low end torque
Old 12-08-2011, 08:57 AM   #4 (permalink)
HAHA
Hydroline3 - '09 Mitsubishi L200 Business, Double cab
90 day: 40.86 mpg (US)
Manipulating the air intake is a known method to tune the torque.
Some engines utilizes variable length intakes to optimize torque for a wider rpm-range.
Lowering the weight of the vehicle will give you many benefits somewhat similar to more engine torque.
A heavier flywheel may give you better low end torque. However, this has been argued not be good for FE (at least P&G).
The Following User Says Thank You to HAHA For This Useful Post:
Kodak (12-08-2011)
