Originally Posted by Sven7
If this were true, why would companies even bother with optional 4WD? Why not just make all their trucks permanent 4X4's?
The trucks with part time 4WD usually have a 4WD mode where the front and rear axles are locked together. You should only use it on
loose surfaces, not on dry, wet, or icy roads.
