Old 12-08-2011, 03:00 PM   #30 (permalink)
kach22i
Originally Posted by winkosmosis View Post
The trucks with part time 4WD usually have a 4WD mode where the front and rear axles are locked together. You should only use it on loose surfaces, not on dry, wet, or icy roads.
People use 4WD in the snow and wet roads all the time, which is why such trucks exist in the marketplace. To say never use it unless on loose surfaces may be correct, but not realistic in my opinion.
I limit my 4WD use as much as possible, two sand tubes over the rear axle helps.
My multiple aerodynamic improvements; front chin spoiler, roof cab wing, and rear spoiler all help to keep her on the road at speed.
