Old 05-20-2008, 11:48 PM   #9 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.59 mpg (US)
Originally Posted by igo View Post
Here is one idea. Take off your throttle body and dremel the throttle plate to a knife edge. I did this on my pervious car and it seemed to make the pedal more responsive but, you can screw up your car if you take off too much material.
This idea is actually widely used as a performance mod on sports cars, it is often referred to as "porting" the throttle body. It involves doing what you just mentioned, as well as removing as much excess material from the inside of the TB as possible, including even some of the shaft, partially covering any holes for vent lines, IAC valve etc etc. This is done largely to increase throttle response as you mentioned. However, as odd as it may sound, decreased throttle response is really my goal.
