Here's my thinking.
The minimum speed limit thing as fas as I can tell is total BS. I read through the Indiana code on speed limits and no such mention of unposted minium speed limits are mentioned. If there is such an animal I don't know where to find it. If somebody can show me where it is in the law, I'll back down.
Doax is right about the "low speed vehicle" thing. There's a difference between a "low speed vehicle" and a vehicle traveling at low speed. Based on what I found, "low speed vehicle" is a term used to describe a class of vehicles such as farm tractors, gold carts, etc. which are incapable of high speeds.
At this point, I'm not sure I did break the other law. It reads,
A person may not...slow down or stop a vehicle...unless the movement can be made with reasonable safety.
With regard to the first incident (the "stopping"), if there's no one behind me how can that not be considered "reasonably safe"? That incident is the one he said the ticket was for (not the going 28 in a 60).
I did find another section of the law which may be applicable:
IC 9-21-5-7
Reduction of speed; impeding normal and reasonable movement; right-of-way to other vehicles
Sec. 7. A person may not drive a motor vehicle at a slow speed that impedes or blocks the normal and reasonable movement of traffic, except when reduced speed is necessary for safe operation or in compliance with the law. A person who is driving at a slow speed so that three (3) or more other vehicles are blocked and cannot pass on the left around the vehicle shall give right-of-way to the other vehicles by pulling off to the right of the right lane at the earliest reasonable opportunity and allowing the blocked vehicles to pass.
As added by P.L.2-1991, SEC.9.
I don't know as this is relavant at all, since I wasn't cited for it but let's go with it anyway. I could see where it's arguable if I was cited for this. In my book I'm not "impeding or blocking" the normal and reasonable movement of traffic if the left lane is clear and people can pass me easily.
