Old 12-08-2011, 06:00 PM   #7 (permalink)
SolarCedar
Selling my lovely bug
Wilderness EV Electric Vehicle Conversion Kit #2 for VW's including a D & D ES-15A Series motor 40 HP Peak - 12 HP Continuous, Alltrax 7245 (vdc/450 amp) Controller, an adapter plate, Shaft coupler -motor to flywheel, 0-5k Throttle box, Contactor - Kilovac EV200 (2000 amp rupture 200 amp continuous),Fuse - 500 amp slow blow, 50 mv - 500 Amp shunt, 0-150 VDC Volt meter, 0-500 Amp meter, Gage
Bracket for meters, battery charger - 12vdc 6/4/2 a,[ (smart charge) and attending cables and terminals. 9 - 8 volt batteries power the 72 volt system. 1 - 12 volt battery power;the lights, wipers, fan, heater, horn, etc. The vehicle has a top speed of 55 mph with a range of up to 45 miles.
I repainted it from a gray to a pearl blue, put new wheels on it, air shocks in back, replaced the window roll-up mechanism and window seals. Its sweet!
The batteries have died after much use. They were cheap walmart Energizer GC8 batteries. I was going to replace them with AGM batts but lost my job and can't afford to do that. Unfortunately I removed the batteries, the rack and the Rhino lined box they were in. The warranty is expired for the batteries. It wasn't that easy to get a Walmart any way as I live about 40 miles from one and my bug doesn't have the speed needed to go on the highway (the only way to get there from my small rural town). Too dangerous to drive it with all those big 4X4 oil drilling and fracking trucks going 95 mph and riding up behind me.
It is all in my garage waiting for the perfect DYI person to come along and continue the saga. I have put about $9000 into the whole thing since May of 2009.
