Old 12-08-2011, 06:46 PM   #47 (permalink)
Ardent
Originally Posted by 66sprint6 View Post
What? Why? When you go around a corner, your tires turn at different speeds which is where the diffs come in. What would make a transfer case need to act as a diff?
Because the circle traveled by the front tires will be of a larger diameter than that of the rear wheels, just like the circle traveled by the outer wheels is larger than that of the inner wheels.
