Originally Posted by winkosmosis
It's not designed for that. If you read your manual, you'll see that it's meant for loose surfaces only.
Loose surfaces...meaning...wet roads, icy roads, gravel roads, dirt roads, Dusty Rhodes etc? Glad we could all finally agree on that point
I will continue to use my 4wd on icy slick roads, its proven itself safer and if it stresses the drivetrain...so be it, better than endin up in a ditch or worse. Hell, even off road your not ALWAYS on loose surfaces and to tell the truth, I, as will be the case with most people, am alot harder on my truck off the road in 4wd that I am on an icy, slick, "loose" surface street.
Sorry to be a part of the major HiJack in progress, if this thread is ever meant to get back on track I will try to start by sayin, I happened to be at the hardware store and thought about this thread and a couple others so I grabbed up some edging for myself, hope to have some good weather this weekend to mess with it some!
Matt
