I wouldn't play around with carbs too much if you want to restrict it. You could change the jets to smaller ones but then you have to make sure you are not going to run the engine too lean so it would take some tuning. I had a GS 500 about 8 years ago and played with the carbs to get more power, i ended up getting horrible gas milage because i couldn't get the air fuel mixture set right.
Get a 250 or even a 125 and you should be good
