Thread: Low end torque
Old 12-10-2011, 06:24 PM   #14 (permalink)
bhazard
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Originally Posted by Patrick View Post
Move the timing belt on the cam pulley a tooth or two?
This is not a good idea at all. Most of the time one tooth can be 8 degrees or more and can mean the difference between the engine running at all or not. And then theres the interference part of it.
This is why theres adjustable cam gears. Not sure if the Atlas has a big aftermarket or not. Even then theres the VVT to deal with. In this case some sort of tuner would probably take the role of the cam gears.
I'd suggest advancing the ignition timing 1-2°. I've read that (on Hondas anyway) every degree advanced you move on ignition timing moves the torque curve down about 300rpm. Go too far and you'll start getting predetonation, but typically 1-2° is safe. You'll hear it if there's predetonation, it generally sounds something like marbles dropped on glass.
To advance ignition timing, first make a line on your distributor and motor at the stock setting (often 16°) and the turn the distributor slightly. The direction that makes idle go up is advancing.
If you have a timing light, the flywheel has markings for stock, -2° and +2° usually.
Sorry, but an extremely moot post. Im not sure if distributors were even used this century. Ignition timing is completely controlled by the ECU.
Originally Posted by JRMichler View Post
Mine also has the 3.73 rear axle ratio. That mild vibration is a lot more noticeable at 700 RPM, but it doesn't seem to hurt anything.
I would be afraid of the main bearings being beat to bits lugging that low. I could be wrong though.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
The Following User Says Thank You to bhazard For This Useful Post:
Frank Lee (12-10-2011)
