Thread: Low end torque
Old 12-11-2011, 02:33 PM   #20 (permalink)
Ladogaboy
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Wouldn't the optimum timing be the same regardless of whether you're trying to boost low end torque or not (especially with knock-sensor equipped systems)?
It would; however, most manufacturers "dumb down" the timing to be on the safe side. It can *usually* be increased safely by at least a couple of degrees, but yes, there should be knock detection. I can't speak for all cars, but my car has two timing maps (one standard and one for when knock is detected). You'd really have to crack the ECU's coding to know for sure. I'd recommend checking online forums for people with similar cars who might have already messed around with the ECU.
