Old 12-12-2011, 07:05 PM   #5275 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by harlequin2 View Post
A bad solder connection seems unlikely.
What is the error condition that a flashing led indicates?
There is only 5 error codes that will make the led flash.
Throttle fault
High pedal lockout
Vref fault
Motor overspeed
And precharge
Did you have to cycle the key to get the code to clear? If so, it makes me think Vref fault, or throttle fault.
If it just went away from heating, I would say high pedal lockout. For this you would have to check your throttle and throttle settings. Dd you ever calibrate the throttle? If not, you might be right on the edge of going into throttle fail.
If you have a laptop an can get some data from the controller it would be great to see what's going on on start up.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
