Originally Posted by amino
The led was flashing as it normally does when you switch on and is supposed to stay steady after the contactor closes, if all is well.
How do you tell what condition the led is flashing? The Kelly controller has error codes, but I don't think the Open Revolt with the rev. 2C control board does.
Amin
The error codes are only reported through the serial port. The led only shows that there is an error present.
-Adam
