Old 12-12-2011, 09:16 PM   #5280 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Try:
rtd-period 500 (NOT IDLE! WHAT THE CRAP WAS i THINKING?! Thanks Adam!)
That will start to display things like the error code, throttle position, current, temperature, etc... at a 500ms rate. Choose whatever rate you want. Then,
TR = throttle
CR = current reference
CF = current feedback
PW = pulse width
HS = heat spreader temperature
RT = raw throttle
FB = fault bits (THIS ONE IS IMPORTANT!!!)
BA = battery amps
AH = amp hours used
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
amino (12-12-2011)
