Old 12-13-2011, 12:39 PM   #9 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Some of the folks over at Cummins Forum are noting warm up time quite a bit quicker and to higher temps (using a scan tool to read the stock sensor). I'm thinking my warm up looks a lot slower than others because of where I measured it. The stock sensor is right by the heater so that should show a quicker rise and higher temperature than where I measured it down by the water pump inlet.
Snd now that I think about it, since I was measuring at the water pump inlet, there's not really a good way for the coolant I was measureing to mix with the coolant near the heater (it'd be blocked by the pump).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
