Old 12-14-2011, 07:31 AM   #4 (permalink)
Daox
You'll definitely see an increase from getting rid of the automatic transmission. Weather its worth all the work is up to you. If you do decide to go that route, a 5 speed from a 95+ Tercel is the transmission you want as it has the lowest 5th gear ratio.
