Old 12-14-2011, 06:30 PM   #36 (permalink)
TXwaterdog
EcoModding spendthrift
WindedWarrior - '12 Ford Focus SE
90 day: 33.46 mpg (US)
If you drill into your metal make sure to seal it with something. I personally like clearcoat (clearcoat spray/touchup paint) or silicon depending on what I'm putting through the hole. Most of the times I use both If I'm pulling wires that might move around. For cold fusion (nuts and bolts) I always dab some clearcoat on the inside of the holes and wait the proper amount of time for it to dry. Sure it's another step that takes 2hours+ but it's needed in my mind.
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
The Following User Says Thank You to TXwaterdog For This Useful Post:
Rurfen (12-14-2011)
