Forgot to post it; 4 x 2. Thanks for the catch Big Dave.
I am planning on dropping front 2" and rear enough to level it (say 3-4"). The kit is in the garage.
Cannot swap to manual as I tow and A/T is better to tow. GearVender is many $'s, but you get 8 speed A/T with lower 1st gearing ~8% and top end gearing is taller by ~18% if you also swap from 3.55 to 3.73 rearend gearing. This helps towing and cruising with no load.
I think the GearVender will be workable if I can get a bit more HP/torque at 1,800 RPM + reduce air drag.
Jerry
