Originally Posted by Peter7307
No it doesn't.
Removing the key and locking the door locks the door and that is all.
If someone can gain access to the car they can still hotwire the ignition and drive the car away.
So you know more about how my car is built than the Honda engineers that designed the system? The key has an electronic chip in it. If it isn't within a very short distance of the ignition, it disables the ignition/ECU. Cutting an identical key without a chip won't start it. Of course a determined thief could shift into neutral and push it...
Not sure what the comment about "handicap assist transmission" is about.
Otherwise known as automatic transmission.
