Originally Posted by Tango Charlie
Get as invasive as you need to. Don't *****foot around about it. Things WILL strike the pan, and you don't want it coming off. Engineering a break away pan would take a lot of effort and expertise, and in my opinion, ill-advised. It would cause more damage to other parts of the car if it comes loose or partially loose.
Again, my opinion, but don't worry about drilling holes in your car. Drill a hole where you need it, and shoot some Rustoleum on it. Use stainless steel hardware. It'll be fine.
See my Vibe thread. I just had some experience with belly panel damage.
Yes Dad
I'm hoping to use the pre drilled mounting points on the e46 under tray on my car-Luckily its a one Piece and runs back to about the Bulkhead area. I'll make sure its securely fitted as per your advice
I'm not going to drill the car if I can avoid it
these e36's like to rot, and the climate here(365 days of rain PA) mean everything will rot as soon as you look at it
