And here they are after 1 coat primer, 2 coats flat white rustolium, on the car. They look ok but far from perfect. ill probably put them on the rear where they will be mostly hidden by the rear skirts and do a better job on the next set.
Any time I make modifications to my car I like to check the wheels/tires/suspension for clearance, I use the neighbors cat method.
Please note. The above is a joke, no animals where hurt in the ecomodification of this vehicle.
