Old 12-17-2011, 12:06 PM   #3 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by slowmover View Post
Congratulations! Will be interesting to see when it comes back up. How are you figuring local temps to chart or graph, as your skill plus continued mods will affect mpg?
I'm not too far off from being able to re-fill tank at will instead of partial fills. Might spring for a winter cover depending on commute. TX_dj has me sold on an Ultragauge. Ever since you've started the Team Cummins group I've dialled back on shift rpm (DD is never over 1600, I tell myself) and gotten used to catching the next gear by 1,100 instead of 1,300. The overhead tells me I'm better, but . . . .
Thanks, slowmover! As far as when it will come back up, the 29.9 mpg was just a one day thing. I'm still averageing about 34ish on the lie-o-meter (averaging good days, bad days, mornings, evenings, etc). Back when it was warmer I was averaging up closer to 36-37 or so. In the last month or so the temps have averaged in the low 30's--that doesn't help. A couple days ago, it warmed up a little for about 2 days (temps in the 50's). Sure enough, for those 2 days I got quite a bit better FE.
I get my temperature data from a local weather station on the Weather Underground site (it really is a weather site--not the 1960's terrorist group ), They have stations all over the US and you can look up historical weather for any day you want (temperature, pressure, humidity, wind speed & direction, precipitation). I've kept a record of every commute since April in a spreadsheet with the weather data, as well as comments on changes I made, mods, route changes, etc. If you're interested PM me your email address and I'll send you the Excel file.
Didn't know you got the Ultragauge from TX_Dj. I knew he was having some trouble with it. I guess he gave up(?) I need to get one but haven't yet. Maybe here soon.
As far as the shifting goes, I guess you'll just have to wait until you get to the pump to find out for sure. I've learned shifting is kind of a habit thing--once you've done it one way for a while it takes some concentration do adjust your normal routine. Let me know how it turns out.
Edit: Just re-read your post and saw TX_Dj sold you on an UltraGauge, not sold you an UG,
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
