Old 12-19-2011, 06:44 PM   #5 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I just sent you the Excel file.
As far as the shifting goes, I agree completely that you need to do things differently when you're actually working the engine. All my previous comments assumed unloaded (which most of my miles are). When you're getting low enough with the rpms that you're getting close to the torque then you gotta shift up. When unloaded it's hard to lug the engine even if you're trying (400+ lb-ft of clutch engagement torque). Loaded is a different story.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
