looks great, I worry a bit about under hood temps on components, perhaps you could put an under hood air temp gauge in somehow, you dont want to cook your electrics, I had an idea to put a very fine screen in front of my Ranger, at a certain ( unknown speed ) the air would back up and go around the screen , but at low city traffic hot day driving the air would go right through the screen to the radiator and under the hood. I am also going to put a former under the screen or maybe use a base of a thicker mesh that will hold a shape to round out the nose of the truck from the present flat configuration , your dodge has an ideal front end shape for a truck with the projected front grill tapering back to the sides, a bullet is about the most streamlined shape you need
