Thread: Moody Diesel
Old 12-20-2011, 09:15 AM   #39 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
wow lost every thing I was writing so Ill try again. the concept of hyd assist is gerat. I hope that you look into the 3000 psi . wall thickness of 1/8 to 1/4 may be a little thin as you know hyd equip is 4 times rated for safety, decompression is going to play a part when you release the stored fluid . I hooked up a system for aarp years ago and it took 3 ten gallon accumulators to start a CAT and the nitrogen precharge was 4500 psi,and it hammered like he-- ,it also cranked and carry the engine to 1800 rpm in as i recall .025 sec so the sign wave of electric power wouldnt drop so they wouldnt loose computer data input if a power failure happened. just design first so t&m isnt wasted, If it dont work on paper get another sheet . hope this helps food for thought. Ron hyho off to work i go
