"Turning off cylinders" is getting beyond what I am comfortable tuning with. I would think that simply cutting off fuel won't do a great deal of good unless you can also eliminate the pumping losses with some sort of inlet and/or exhaust valve control.
The engines I work with are relatively low tech with stock configuration. My philosophy is one to just try maximize what I've got, tuning to the degree in which I am able to do in real world situations. I just go with the theory that any throttle setting that results in about 80 KPA of manifold pressure or less is "cruise" and I'll run as lean as I can without any sign of lean surge (idle range excepted). For my engines this is about 17:1 indicated. After about 80 KPA I feel that I am requiring some serious power and ramp up to about 12:1 at 100 KPA at max HP RPM. This is just my view on things and what I feel comfortable with. There may be a better way.
Robert
'95 Ford E150 4.9L I6 Megasquirt MS1 Custom MSnS Extra
'92 Winnebago Elante 33 RQ Ford 7.5L V8 Megasquirt MS1 Custom MSnS Extra
'93 Bayliner 3288 Twin Ford 5.8L V8s (351 Windsors) converted to tuned port EFI. Megasquirt MS1 Custom MSnS Extra
