Old 12-21-2011, 01:38 AM   #41 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
I replaced my sons fuel pump and solved his problem( 96 accord) but if i were you i would check the suction line on the pump it could have fallen off. Did you cut a hole in the trunk area when you replaced it, If so it will be real easy to check. also a lot of keys can cause your ignition switch to side load and fail
