Old 12-21-2011, 08:41 AM   #15 (permalink)
3dplane
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Try the same but this time shut your engine off and restart a few seconds later to see if it quit charging then.
I don't think it is easy to shut down a spinning alternator because even though you remove the power from the field winding (the electro magnet) the iron "claws" stay magnetised somewhat and it will keep re-exciting itself as it spins within the stator windings and it's iron core.
(This is why if I were to do this,I would probably go the other rout where I would interrupt the alt. output wire (going to the battery+) with a heavy duty solenoid.However then I'm dealing with having to supply power to this solenoid to keep it open or closed etc.)
Also try it with a bunch of electrical load on,at least that will show the voltage difference better when you get it to quit for you.
Barna
