Thread: WAI on MAF?
Old 12-21-2011, 10:52 AM   #5 (permalink)
Sularus
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
I am not sure blocking air would help. Generally you want more air for lower throttle input. Not higher throttle input with less air. Most computers determine injector pulse width by throttle opening, MAF/MAP input, and O2 sensor adjustment. It would likely cancel itself out, but if it does not, the computer will likely go to rich instead of lean in this instance.
