So are you welding with this circuit or powering a tig welder?
I take it you will be using the output of these 2 half bridge's into a high frequency transformer?
Usually, am inverter tig switch's into a transformer at high frequency and uses the duty cycle and inductance of the transformer to smooth the output and shape the output into more of a sine wave.
-Adam
