barna, I would really not recommend intrupting the big wire. bad idea.
A better way is to hook a light up to the field, then to ground. That way the field can gently ground through the light killing the field magnetics.
when you put power to the field, it will still energize the field, and turn the light on. LED's are not suitable for the light - it must be an old fashioned incandescent.
