Old 12-21-2011, 03:31 PM   #3 (permalink)
drmiller100
you need two wires to make a 90 and newer honda alternator work. The big white wire do not mess with - it is the "direct to battery" wire.
IN the harness.there is a black and yellow wire. energize it and the alternator works. remove power and Ground it "gently" through a light bulb, and it will quit charging.
